AMD Ryzen 5 3600 CPU benchmarks Leak
AMD’s Ryzen 5 3600 is the company’s cheapest Zen 2 processor, at least at the company’s July 7th Launch, offering users six cores, twelve threads and base/boost clock speeds of 3.6/4.2GHz for $199 while delivering more single-threaded CPU performance than a Ryzen 7 2700X.
In the images below, which come via Videocardz, the Ryzen 5 3600 operates using 3200MHz DDR4 memory at CS 14 timings and offers 502.2 points in CPU-Z’s single-threaded benchmark and 3989.4 points in CPU-Z’s multi-threaded benchmark.
| Cores | Threads | Base Clock | Boost Clock | L2 + L3 Cache | PCIe 4.0 | TDP | Price | |
| Ryzen 9 3950X | 16 | 32 | 3.5GHz | 4.7GHz | 8+64 MB | 16+4+4 | 105W | $749 |
| Ryzen 9 3900X | 12 | 24 | 3.8GHz | 4.6GHz | 6+64 MB | 16+4+4 | 105W | $499 |
| Ryzen 7 3800X | 8 | 16 | 3.9GHz | 4.5GHz | 4+32 MB | 16+4+4 | 105W | $399 |
| Ryzen 7 3700X | 8 | 16 | 3.6GHz | 4.4GHz | 4+32 MB | 16+4+4 | 65W | $329 |
| Ryzen 5 3600X | 6 | 12 | 3.8GHz | 4.4GHz | 3+32 MB | 16+4+4 | 95W | $249 |
| Ryzen 5 3600 | 6 | 12 | 3.6GHz | 4.2GHz | 3+32 MB | 16+4+4 | 65W | $199 |
In Cinebench R15, AMD’s Ryzen 5 3600 achieved a benchmark score of 1443 points, which is enough to surpass our Intel i7 8700K’s benchmark score of 1429 (link for benchmarking data). Not bad for a $199 processor.
Sadly, CInebench’s single-threaded benchmark was not run using this hardware configuration, leaving us with only the application’s multi-threaded performance results.
In Cinebench R20, we can see that the Ryzen 5 3600 offers a multi-threaded score of 3229, which gives this 6-core processor similar performance levels to AMD’s 8-core Ryzen 7 1700X. In effect, AMD has packed two cores of extra performance into their 6-core Ryzen 5 3600. Not bad given the fact that this is AMD’s lowest-end Zen 2 offering.
So far, these are impressive results for AMD’s Ryzen 5 3600, but it only paints part of the picture. Yes, heavily multi-threaded benchmarks are good, but what about scenarios that are more single-thread limited, such as gaming workloads or more mainstream computing applications. We will cover this and more during our full Ryzen 3rd Generation reviews.
You can join the discussion on AMD’s Ryzen 5 3600 CPU benchmark leaks on the OC3D Forums.
