AMD Ryzen 5 5600U specs leak showcases significant performance boost over 4600U
AMD Ryzen 5 5600U specs leak showcases significant performance boost over the 4600U
AMD’s Ryzen 5000 series of mobile processors are due to deliver Zen 3 to the mobile market alongside continued boosts to AMD’s mobile performance and efficiency.
If recent rumours are to be believed, AMD’s Zen 3 mobile silicon is codenamed Cezanne, and it will feature AMD’s Zen 3 CPU core architecture alongside a refined Vega-based graphics component.
According to a leaker called ExecutableFix, AMD’s upcoming Cezanne 6-core, the Ryzen 5 5600U will feature a CPU base clock of 2.3GHz and a CPU boost clock of 4.2GHz. On top of that, the APU will feature 7 Radeon CUs which are clocked at 1.8GHz and a TDP range of 10W-25W.
When compared to today’s Ryzen 5 4600U, which features the same core count and TDP rating, AMD’s Ryzen 5 5600U will feature 200MHz increased to its CPU base/boost clocks, an integrated GPU which features an additional Vega CU and a 300MHz boost in graphics clock speed. After adding the benefits of AMD’s Zen 3 core architecture into the mix, AMD’s Zen 3 Ryzen 5000 series mobile processors are due to deliver AMD a significant performance boost over their 4000 series predecessors.
At this time, it is unclear when AMD will reveal its Cezanne series of Ryzen mobile processors. AMD could unveil their next generation of Ryzen mobile processors at CES 2021, highlighting their performance and efficiency gains over today’s Renoir offerings.
You can join the discussion on AMD’s rumoured Ryzen 5 5600U processor on the OC3D Forums.
