AMD’s “Zen 2” IPC is 29.4% higher than Zen 1 in DKERN +RSA
Within the footnotes of AMD’s press release lies an exciting tidbit of information, detailing how AMD’s performance per clock, or rather Instruction Per Cycle (IPC), has increased over their 1st generation Zen processors, giving us our first glance at Zen 2’s throughput.
In DKERN +RSA AMD’s Zen 2 architecture offered a staggering 4.53 IPC score, while their “Zen 1” generation CPU achieved 3.5 IPC, giving Zen 2 a boost of 29.4%. Some websites have been fixated on this 29.4% number, forgetting its context, but let’s have a better discussion as to this data’s relevance.
As AMD’s footnotes confirm, this data refers to IPC (Instructions Per Cycle), which means that clock speeds should not play a major role here, making this 29% boost down to pure architectural advancement, not an increase in clock speed alone. It is also worth noting that this benchmarking data includes both floating point and integer benchmarks, which is another factor that is worth considering.
Estimated increase in instructions per cycle (IPC) is based on AMD internal testing for “Zen 2” across microbenchmarks, measured at 4.53 IPC for DKERN +RSA compared to prior “Zen 1” generation CPU (measured at 3.5 IPC for DKERN + RSA) using combined floating point and integer benchmarks.
On the core side, Zen 2 offers a redesigned execution pipeline, featuring an improved branch predictor, a re-optimised instruction cache, better instruction pre-fetch and a larger Ops Cache, all of which will help increase Zen 2’s IPC (performance per clock) in a variety of workloads. Early leaks have suggested that AMD’s Zen 2 architecture will offer a 13+% boost in performance over Zen 2 in standard non-AVX applications, though AMD has not confirmed this data.
Like every architectural leap in processor design, performance boosting techniques are largely application dependent, with each design change delivering performance advances to specific aspects of a processor’s functionality, rather than offer a ?% gain in every application under the sun.
When combined with possible clock speed boosts, AMD’s Zen 2 processors could offer a significant leap over their Zen/Zen+ counterparts over a range of PC applications, though we will have to wait a while before we start seeing real-world performance numbers from AMD’s next-generation CPU designs.
You can join the discussion on the IPC improvements of AMD’s Zen 2 architecture on the OC3D Forums.
