Cooler Master release their MasterBox Q300 series of MATX cases
Cooler Master has officially released their new Q300 series of compact MATX cases, offering LAN-ready form factors which are designed with easy transport in mind.
The core Q300 design will ship with two models, with Q300P with dark mirror front and top panels, RGB lighting and four easy carry handle.  The Q300L is Coller Master’s affordable alternative chassis, offering pattern dust filters and a single, removable carry handle.
The Q300P will ship in the UK for £64.99, and the Q300L will retail for a more affordable price of £39.99. Both cases support up to a 240mm radiator at the front of the chassis, making them suitable for use with AIO liquid coolers.
Cooler Master has designed this chassis to meet the needs of the MATX market, which is often ignored by case manufacturers. Both of these case designs are set to offer their users value and features that enable easy transport to LAN events.
      Cooler Master release their MasterBox Q300 series of MATX cases  Cooler Master release their MasterBox Q300 series of MATX cases
The I/O of this chassis is designed to sit in one of six different locations on the motherboard, with the panel being mountable on either side of the frame with three different orientations in each side, allowing the I/O to be placed wherever it is most convenient for the user.
The Q300L will ship with a single 120mm fan at the rear of the chassis, while the Q300P offers two 120mm RGB fans at the front of the enclosure and a single 120mm fan in the back. Both cases support standard ATX power supplies (maximum length of 160mm) and 2x 2.5-inch drives and a single 3.5-inch drive.
Both of these cases are now available to order in the UK, with the Q300P costing £64.99 while the Q300L will retail for £39.99.
You can join the discussion on Cooler Master’s MasterBox Q300 series of cases on the OC3D Forums.
