EK confirms Threadripper 3rd Gen compatibility for its Velocity Series TR4 Water Blocks
EK’s Velocity series Thredripper water block ships with an improved fin structure when compared to EK’s older block designs, enabling improved cooling performance and lower levels of in-loop friction. EK’s sTR4 Velocity water block is designed to feature 91 micro-fins to cover the entire die area of AMD’s Threadripper series processors, making this block ideal for all of today’s Threadripper processors, even AMD’s planned Ryzen Threadripper 3990X.
D-RGB compatible Velocity water blocks are designed with support with all of today’s RGB motherboards, connecting via commonly used 3-pin addressable LED connections. The block’s standard RGB version, the “EK-Velocity sTR4 – Full Nickel”, uses a 4-pin connector and supports most modern RGB enabled motherboards.
EK’s new Velocity series TR4 water blocks will be produced in Slovenia and are now available for purchase, starting at €99.90 for the non-RGB versions, €109.90 for the Plexi/Acetal RGB versions and €129.90 for the Full Nickel version.
You can join the discussion on EK’s 3rd Generation Velocity series TR4/Threadripper water block on the OC3D Forums.
