EK reveals their first X470 series monoblock for ASUS’ ROG Strix X470-F
This monoblock will cool both the user’s CPU and the motherboard’s power circuitry, keeping both heat sources cool to ensure minimal system noise when combined with a well thought out water cooling loop. This block will also feature ASUS AURA compatible RGB lighting, which can use a 4-pin RGB connection on the X470 Strix-F to offer a fully adjustable lighting experience.
Like all of ASUS’ other X470 monoblock designs, the EK-FB ASUS Strix X470 RGB Monoblock is made using nickel-plated copper with a Supremacy EVO heat plate for CPU cooling. The block also directly cools the motherboard’s MOSFETs, circulating liquid to all vital areas. The top of the block is made using an acrylic glass material, making it extremely suitable for RGB illumination.
EK plans to release this monoblock on their web store for €139.90 on their EU web store, with a release date of May 8th. This monoblock is specific to ASUS’ ROG Strix X470-F Gaming motherboard, lacking support for the company’s other X470 board designs on the Strix’s X370-based counterpart.
You can join the discussion on EK’s ASUS ROG Strix X470-F Gaming monoblock on the OC3D Forums.
