Intel’s leaked 10th Gen i3 will be a pre-Zen i7 – The power of competition
Intel's leaked 10th Gen i3 will be a pre-Zen i7 - The power of competition
Since the release of AMD’s Zen architecture in 2017, the consumer PC market has been transformed. Before then, Intel was dominant, so much so that the silicon giant had become complacent. Quad-core desktop processors had become the norm, and Intel’s single-threaded performance leadership gave them little reason to push core counts higher. This changed with the release of Ryzen.
Now, Intel’s 10th Generation of desktop CPUs is rumoured to offer 10-core models, boosting Intel’s core counts by 2.5x on its mainstream desktop socket. Stranger still, is that Intel’s pre-Zen i7 specs are also rumoured to become the baseline of Intel’s Core i3 series. That’s right, in three years, Intel i7 has been relegated to i3 status.
From 2017 to 2020, it looks like Intel’s i3 series will see a 2x increase in core/thread count, which when combined with clock speeds boosts yields a better than 100% performance gain total accessible performance. Would this have happened without AMD’s competitive Zen offerings, probably not, or at a minimum, not this soon. What was a Kaby Lake i7, will become Comet Lake’s i3, assuming Comet Lake’s long-term rumours hold true.
2017's Intel i7 will become 2020's i3 - Comet Lake brings Hyperthreading to Core-i3
Leaks regarding Intel’s Comet Lake series date back to early 2019, with older leaks of Intel’s i3-10100 processor confirming the base clock speeds and core/thread counts that are seen in recent processors leaks from Informatica Cero, via Videocardz.
Comet Lake is due to be Intel’s next series of 14nm processors, and rumour has it that Intel’s entire core lineup will feature Hyperthreading, with a 10-core i9 processor sitting at the top. This would give i5 six cores and twelve threads, i7 eight cores and sixteen threads and i9 ten cores and twenty threads. Yes, the core architecture will still be Skylake, but with Comet Lake Intel plans to push AMD’s Ryzen lineup in the realms of pure PC performance.
Below are the leaked specifications of Intel’s 10th Generation desktop processors.
  Cores/Threads Base Clock Single Core Turbo All Core Turbo Turbo Boost 3.0 Velocity Boost TDP
i9-10900K 10/20 3.7 GHz 5.1 GHz 4.8 GHz 5.2 GHz +100MHz 125W
i9-10900 10/20 2.8 GHz 5.0 GHz 4.5GHz 5.1 GHz +100MHz 65W
i7-10700K 8/16 3.8 GHz 5.0 GHz 4.7 GHz 5.1 GHz – 125W
i7-10700 8/16 2.9 GHz 4.7 GHz 4.6 GHz 4.8 GHz – 65W
i5-10600K 6/12 4.1 GHz 4.8 GHz 4.5 GHz – – 125W
i5-10600 6/12 3.3 GHz 4.8 GHz 4.4 GHz – – 65W
i5-10500 6/12 3.1 GHz 4.5 GHz 4.2 GHz – – 65W
i5- 10400 6/12 2.9 GHz 4.3 GHz 4.0 GHz – – 65W
i3-10320 4/8 3.8 GHz 4.6 GHz 4.4 GHz – – 65W
i3-10300 4/8 3.7 GHz 4.4 GHz 4.2 GHz – – 65W
i3-10100 4/8 3.6 GHz 4.3 GHz 4.1 GHz – – 65W
While Intel has plans to release a 10-core processor, AMD has already delivered a 16-core desktop processor in its AM4 platform, leaving Intel behind in terms of core/thread counts. Even so, Intel plans to compete with higher levels of single-threaded performance, which will come thanks to boosted core clock speeds.
You can join the discussion on Intel’s 10th Generation Comet Lake i3 being a pre-Zen i7 on the OC3D Forums.
