Acer Unveils their Predator XB321HK 32″ 4K G-Sync Monitor
Acer has just unvieled their new Predator XB321HK 32″ 4K G-Sync Monitor, offering 100% sRGB coverage, 10-bit colour and an IPS panel with 4ms response times.
Thsi display uses DisplayPort 1.2 and can also use HDMI, though Nvidia’s G-Sync will only work through DisplayPort, the monitor will also contain a USB 3.0 hub and contain stereo speakers with enhanced DTS sound.
With this screen being so large the stand is only able to offer 4.7 inches of height adjustment and can be tilted from -5 to 25 degrees. This monitor cannot be used in a portrait configuration.
Below are the display’s full specifications:
– Screen Size Class (diagonal): 32″
– Panel Type: IPS
– Aspect Ratio: 16:9
– Resolution: 3840×2160
– Refresh rate: 60Hz
– Brightness (typical): 350 cd/m2
– Contrast Ratio(Original): 100M:1
– Response Time: 4ms
– Viewing Angle (CR>10): 178/178
– 1.07B Colour support
– 10-Bit
– Connectivity: 1x HDMI 1.4 & 1x DisplayPort
– Speakers: 2x 2W
– Tilt: Yes
– Height Adjust: Yes
– USB 3.0 Hub
– VESA: 100 x 100
– Warranty: 2yr (With Acer)
Acer has given this monitor an MSRP of £799.99 in the UK and is currently available at Overclockers UK for the slightly lower price of £779.99.
You can join the discussion on Acer’s Predator XB321HK 4K G-Sync Monitor on the OC3D Forums.
