AMD launches their 20.11.3 driver for Immortals: Fenyx Rising and Vulkan Ray Tracing
Alongside these new additions comes a large number of bug fixes, most of which address early issues with AMD’s Radeon RX 6000 series. Many of these issues relate to games which utilise DXR raytracing or other forms of ray tracing acceleration. It is worth noting that these games were developed without AMD’s ray tracing acceleration technology in mind.
AMD has also released a long list of known issues, which should be addressed with upcoming Radeon Software releases. Below are AMD’s full Radeon Software 20.11.3 release notes.
Support For
– Immortals: Fenyx Rising
– Vulkan Ray Tracing Extensions
Added Vulkan Support
– VK_KHR_fragment_shading_rate
– This extension provides the ability to change the shading rate per fragment. This extension allows for multiple pixels to be shaded via a single fragment shader invocation as opposed to the normal rate of one invocation per pixel.
– VK_KHR_acceleration_structure
– This extension provides acceleration structures for representing geometry that is spatially sorted. Acceleration structures are the most common way for quickly identifying potential ray intersections by ray tracing techniques.
– VK_KHR_ray_tracing_pipeline
– This extension introduces ray tracing pipelines along with new shader domains and an indirection table to link shader groups with acceleration structures.
– VK_KHR_ray_query
– This extension introduces ray queries, which can be used by any shader type outside of the optional dedicated ray tracing pipeline to return traversal results to the calling shader.
– VK_KHR_deferred_host_operations
– This extension defines the infrastructure and usage patterns for deferrable commands, which allows dependent extensions to defer their own operations. The VK_KHR_deferred_host_operations extension itself does not specify any commands as deferrable.
– VK_KHR_pipeline_library
– This extension introduces pipeline libraries. A pipeline library is a new special pipeline type that defines a set of pipeline states. It cannot be bound, rather it can be linked into other pipelines.
– VK_KHR_shader_terminate_invocation
– This extension indicates support for the SPV_KHR_terminate_invocation SPIR-V extension. The SPIR-V extension introduces a new instruction OpTerminateInvocation that allows a shader invocation to immediately terminate, which provides the behavior required by the GLSL discard statement.
Fixed Issues
– Lower than expected performance may be experienced on Radeon™ RX 6000 series graphics products in Watchdogs:® Legion and Dirt™ 5.
– Lower than expected performance may be experienced on Radeon™ RX 5000/500/400 series graphics products in Godfall™.
– Godfall™ is not detected or listed in Radeon Software gaming tab.
– Crysis™ Remastered may experience corruption on character models on Radeon™ RX 6800 Series graphics products.
– Fixed some intermittent crashes found in Total War™ Saga: Troy and World of Warcraft®: Shadowlands.
– World of Warcraft®: Shadowlands may fail to launch when DirectX®12 API is selected on Windows®7 system configurations.
– Fixed some intermittent crashes found in Call of Duty®: Black Ops Cold War with DirectX® Raytracing enabled.
– HDR on supported Windows 10 desktops might get disabled when DOOM® Eternal™ starts rendering in HDR mode.
– Fixed issues found on Adobe™ Illustrator, Adobe™ Premier and FinalWire AIDA64.
– Fixed corruption issues in Red Dead Redemption 2 in 1080p resolution on Radeon™ RX 6800 Series graphics products.
Known Issues
– Brightness flickering may intermittently occur in some games when Radeon™ FreeSync is enabled, and the game is set to use borderless fullscreen.
– Metro Exodus™, Shadow of the Tomb Raider™, Battlefield™ V and Call of Duty®: Modern Warfare may experience intermittent application crashes with DirectX® Raytracing enabled.
– Anisotropic Filtering in Radeon™ Software graphics settings is not taking effect in DirectX®9 applications on RDNA graphics products.
– Some games may experience stuttering when set to borderless fullscreen and an extended display is connected running the Netflix™ windows store application on RDNA graphics products.
– Radeon™ recording and streaming features may fail to enable on AMD Radeon™ HD 7800 series graphics products.
– Modifying the HDMI Scaling slider may cause FPS to become locked to 30.
– Performance Metrics Overlay and the Performance Tuning tab incorrectly report higher than expected idle clock speeds on Radeon™ RX 5700 series graphics products. Performance and power consumption are not impacted by this incorrect reporting.
– Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
– Oculus Link users might experience crashes on Polaris and Vega series graphics products.
– Flickering might be observed if the Radeon Software Overlay is invoked while Immortals: Fenyx Rising™ is running on an extended display.
– Tom Clancy’s Rainbow Six® Siege might experience corruption in Hybrid Graphics scenarios when using the Vulkan API on an extended display.
– Screen flickering might be observed when using MSI Afterburner.
Desktop GPUs
Radeon Desktop Product Family Compatibility
Radeon RX 6800 XT Radeon RX 6800 Radeon RX Navi 5700/5600 Series Radeon VII Radeon RX 5500 Series RX 5300M (Notebook GPU) Radeon RX Vega Series AMD Radeon Pro Duo Radeon RX 580/590 AMD Radeon RX 570 Radeon RX 560 AMD RX 550 Radeon RX 400 Series Graphics AMD Radeon R7 300 Series Graphics AMD Radeon Pro Duo AMD Radeon R7 200 Series Graphics AMD Radeon R9 Fury Series Graphics AMD Radeon R5 300 Series Graphics AMD Radeon R9 Nano Series Graphics AMD Radeon R5 200 Series Graphics AMD Radeon R9 300 Series Graphics AMD Radeon HD 8500 – HD 8900 Series Graphics AMD Radeon R9 200 Series Graphics AMD Radeon HD 7700 – HD 7900 Series Graphics
Supported APUs
AMD Ryzen Mobile Processors with Vega Graphics AMD Athlon Mobile Processors with Vega Graphics AMD A-Series and FX Processors with Radeon Graphics AMD Ryzen pro Mobile Processors with Vega Graphics AMD Athlon Pro Mobile Processors with Vega Graphics AMD A-Series Pro Processors with Radeon Graphics
Download Links
– Windows 10 (64-bit)
You can join the discussion on AMD’s Radeon Software Adrenalin Edition 20.11.3 driver on the OC3D Forums.
