AMD’s Radeon Software 21.2.3 driver is ready for DIRT 5’s Energy Content Pack
This driver also contains a series of bug fixes that helps to increase the stability of Radeon-powered systems. This includes an update for the RX 6900 XT which improves compatibility with HP’s Reverb G2 headset, a bug fix that prevents crashing when RX 6000 series users run Substance Painter and a bug that can cause system crashes when hot-plugging HDMI monitors on multi-monitor systems.
Support For
– DIRT 5 Energy Content Pack
Fixed Issues
– HDMI Audio Devices may fail to install on Radeon RX 400 and Radeon RX 500 series graphics products.
– Hot plugging HDMI TV displays in multi monitor system configurations may sometimes cause a system crash or hang.
– An application crash or hang may occur in Substance Painter™ on Radeon RX 6000 series graphics products.
– A system crash or hang may occur on the HP Reverb G2™ when connected to Radeon RX 6900 series graphics products.
– Radeon Software may sometimes fail to gather the latest available Radeon Software versions when performing or checking for updates.
Known Issues
– A system hang or crash may be experienced when upgrading Radeon Software while an Oculus™ VR headset is connected to your system on Radeon GCN graphics products. A temporary workaround is to disconnect the headset before install.
– AMD is currently investigating end user reports that Radeon Software may sometimes have higher than expected CPU utilization, even when a system is at idle. Users who are experiencing this issue are encouraged to file a bug report in Radeon Software.
– Brightness flickering may intermittently occur in some games or applications when Radeon™ FreeSync is enabled, and the game is set to use borderless fullscreen.
– Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
Desktop GPUs
Radeon Desktop Product Family Compatibility
Radeon RX 6900XT Radeon RX 6800 Series Radeon RX Navi 5700/5600 Series Radeon VII Radeon RX 5500 Series RX 5300M (Notebook GPU) Radeon RX Vega Series AMD Radeon Pro Duo Radeon RX 580/590 AMD Radeon RX 570 Radeon RX 560 AMD RX 550 Radeon RX 400 Series Graphics AMD Radeon R7 300 Series Graphics AMD Radeon Pro Duo AMD Radeon R7 200 Series Graphics AMD Radeon R9 Fury Series Graphics AMD Radeon R5 300 Series Graphics AMD Radeon R9 Nano Series Graphics AMD Radeon R5 200 Series Graphics AMD Radeon R9 300 Series Graphics AMD Radeon HD 8500 – HD 8900 Series Graphics AMD Radeon R9 200 Series Graphics AMD Radeon HD 7700 – HD 7900 Series Graphics
Supported APUs
AMD Ryzen Mobile Processors with Vega Graphics AMD Athlon Mobile Processors with Vega Graphics AMD A-Series and FX Processors with Radeon Graphics AMD Ryzen pro Mobile Processors with Vega Graphics AMD Athlon Pro Mobile Processors with Vega Graphics AMD A-Series Pro Processors with Radeon Graphics
Download Links
– Windows 10 (64-bit)
You can join the discussion on AMD’s Radeon Software Adrenalin Edition 21.2.3 driver on the OC3D Forums.
