AOC launches their 40-inch C4008VU8 curved 4K 10-bit display
AOC has now launched their new 40-inch C4008VU8 curved 4K 10-bit display, coming with an MVA panel and support for 85% of the NTSC colour gamut.
Sadly this display does not come with support for variable refresh rate technologies like FreeSync or G-Sync, giving this display a refresh rate of 60Hz. Combine this with this display’s 5ms response time and we have a display that is not well suited to gaming, though it’s large size, high resolution and 10-bit colour support will make it a great option for professional use.
Right now this display is available for purchase at Amazon US for $850 in limited quantities, making it one of the most affordable 4K 40-inch 10-bit PC displays available.
AOC’s C4008VFU8 will come with the following specifications:
  • Viewable Screen Size: 40-inch
  • Panel Type: VA
  • Aspect Ratio: 16:9
  • Brightness: 300 cd/m²
  • Refresh Rate: 60Hz
  • Contrast Ratio (dcr): 20M:1
  • Response Time: 5ms
  • Max Resolution: [email protected]//
  • Color Depth: 1.07B
  • View Angle (degrees) (H x V): Horizontal: 178 Degrees (CR>10) Vertical: 178 Degrees (CR>10)
  • Cabinet Color: White/Silver
  • Adjustability Tilt: -5°±1.5°~+13.5±1.5°
  • Inputs: VGA, HDMI 1.4 (MHL), HDMI 2.0 (MHL), 2 x Display Port 1.2, 4 x USB 3.0 (1 x Fast Charging)
AOC lists this display as having an MSRP of $899.
You can join the discussion on AOC’s 40-inch C4008VU8 curved 4K 10-bit PC display on the OC3D Forums.
