ASUS boasts ambitious Boost clocks with their ROG Strix RTX 3080 OC
ASUS has revealed the specifications of its ROG Strix RTX 3080 graphics cards, confirming ambitious clock speeds for their flagship Gaming OC model. ASUS’ RTX 3080 Strix Gaming models will include a new cooler design from the manufacturer, upgraded fans and feature three 8-pin PCIe power connectors, all of which are designed to get the most out of Nvidia’s Ampere silicon.
With a boost clock of 1935MHz in the graphics card’s OC mode, ASUS’ ROG Strix RTX 3080 Gaming OC has a 225MHz higher boost clock speed than Nvidia’s RTX 3080 Founders Edition model. Only time will tell if this clock speed advantage will deliver gamers more real-world performance.
When we reviewed ASUS’ more entry-level RTX 3080 TUF Gaming OC, we were impressed by ASUS’ cooling solution and the performance that the company could deliver so close to Nvidia’s MSRP pricing. With the ROG Strix model, ASUS promises a more advanced cooling solution, more RGB illuminated elements, higher clock speeds and stronger power circuitry.
Below are the specifications of Nvidia’s RTX 3080 Founders Edition and ASUS’ custom models.
  Nvidia RTX 3080 FE ASUS RTX 3080 TUF GAMING ASUS RTX 3080 TUF Gaming OC ASUS ROG Strix RTX 3080 Gaming ASUS ROG Strix RTX 3080 Gaming OC
Node 8nm 8nm 8nm 8nm 8nm
CUDA Cores 8704 8704 8704 8704 8704
Base Clock 1.44 GHz 1.44 GHz 1.44 GHz 1.44 GHz 1.44 GHz
Boost Clock 1.71 GHz 1.71 GHz (GM)
1.74 GHz (OCM)
1.785 GHz (GM)
1.815 GHz (OCM)
1.71 GHz
(GM)
1.74 GHz (OCM)
1.905 GHz
(GM)
1.935 GHz
(OCM)
Memory 10GB GDDR6X 10GB GDDR6X 10GB GDDR6X 10GB GDDR6X 10GB GDDR6X
Memory Speed 19 Gbps 19 Gbps 19 Gbps 19 Gbps 19 Gbps
Memory Bus 320-bit 320-bit 320-bit 320-bit 320-bit
Power Inputs 1x
12-pin
2x 8-pin 2x 8-pin 2x 8-pin 2x 8-pin
Recommended PSU 750W 750W 750W 750W 750W
ASUS’ ROG Strix RTX 3080 Gaming models will feature dual HDMI 2.1 outputs and three DisplayPort 1.4 connectors, and utilise three 8-pin PCIe power connectors for power. These features make these new graphics cards ideal for connecting to several new HDMI 2.1 devices, which can offer gamers support for 8K displays and 120Hz support on some 4K OLED TVs.
The ROG Strix RTX 3080 Gaming is a 2.9 slot graphics card and is 31.85 cm long.
You can join the discussion on ASUS’ ambitious ROG Strix RTX 3080 Gaming OC Boost Clocks on the OC3D Forums.
