Corsair launches their GTX 1080 Ti Hydro GFX
Corsair has now officially launched their new GTX 1080 Ti Hydro GFX, which was co-designed by MSI and is designed to offer cooler load temperatures and higher clock speeds.
While on paper this GPU only boasts a small factory overclock, in reality, this GPU will offer much higher average clock speeds than Nvidia’s reference/Founders Edition design, as this GPUs lower load temperatures and Nvidia GPU-boost 3.0 allows this GTX 1080 Ti to boost too much higher average clock speeds.
Corsair’s new AIO liquid cooled GTX 1080 Ti will allow users to overclock their GPU without the need to run the GPU with overly loud fans or at high temperatures, giving users more freedom to overclock their new GPU.
This new GPU will be cooled using a custom AIO with a 120mm radiator, which is cooled by a 4-pin PWM Corsair ML120 fan. This fan will come with white LED illumination, though it is replaceable with pretty much any 120mm fan if that colour does not suit your system.
  GTX 1080 Ti Founders Edition Corsair Hydro GFX GTX 1080 Ti
GPU Architecture Pascal Pascal
Process node 16nm 16nm
SM Units 56 56
Cores per SM 64 64
CUDA Core Count 3584 3584
ROPs 88 88
VRAM Type GDDR5X GDDR5X
Memory Clock 11008MHz 11124MHz
VRAM Cappacity 11GB 11GB
Memory Bus Size 352-bit 352-bit
Memory Bandwidth 484 GB/s 484 GB/s
Base clock speed 1480MHz 1569MHz
Boost clock speed 1582MHz 1684MHz
Power Connection
1x 8-pin 1x 6-pin
1 x 8-pin 1 x 6-pin
PCI Express  PCIe 3.0 PCIe 3.0
This new GPU is currently available to purchase on Corsair’s website.
You can join the discussion on Corsair’s new Hydro GFX GTX 1080 Ti on the OC3D Forums.
