EK launch their first GTX 1080 Ti ready GPU water blocks
This water block will come in EK’s standard Nickel+Acetal or Nickel+clear Acrylic variants, with both versions offering the same performance. The Acrylic top variant will feature two pre-drilled 3mm holes for LEDs, which can be used to illuminate the water block.
This new water block design is now available to Pre-order on EK’s online store, with orders shipping on April 12th. The water block itself will cost €119.95, with a matching backplate costing between €29.95 and €37.95.
EK has also created a large list of compatible GTX 1080 Ti GPUs, which is available to view here.
You can join the discussion on EK’s new GTX 1080 Ti GPU water block on the OC3D Forums.
