EK releases RGB water block for Nvidia Founders Edition GPUs
EK’s GTX Founders Edition water block design is easily one of the most interesting on the market today, offer unparalleled compatibility, supporting every Nvidia GTX 10-series Founders Edition Graphics card.
This block design supports the GTX 1060, GTX 1070, GTX 1080, GTX 1080 Ti, GTX Titan X Pascal and GTX Titan Xp graphics cards, allowing every Nvidia reference design to be supported. Nvidia’s GTX 1070 Ti is expected to work with this water block, given its similarity to Nvidia’s GTX 1080 and 1070, though this has not been confirmed by EK.
This unit is EK’s first RGB GPU water block, utilising an RGB LED strip on the base of the GPU’s water block in a similar way to EK’s already popular RGB CPU/Motherboard monoblock designs.
The block itself doesn’t appear to have any significant design changes over EK’s original block design, which means that the cooling performance of this RGBified design is expected to be identical.
The RGB functionality of this GPU uses a single 12V 4-pin RGB cable, which can be used with ASUS Aura Sync, Gigabyte RGB Fusion, MSI Mystic Light and ASRock RGB LED control software, allowing these functions to be used with every major motherboard manufacturer.
This new water block design will ship at a price of €129.95 on the EK web store (including VAT), with purchases starting today.
You can join the discussion on EK’s new RGB GTX 10-series Founders Edition water block on the OC3D Forums.
