EK releases AMD Radeon R9 Nano Full-Cover water block
EK Water Blocks, Ljubljana based premium computer liquid cooling gear manufacturer, is excited to launch the true single-slot liquid cooling solution for AMD Radeon reference design R9 Nano graphics card.
  EK releases AMD Radeon R9 Nano Full-Cover water block  EK releases AMD Radeon R9 Nano Full-Cover water block
EK-FC R9 Nano directly cools the GPU, HBM as well as VRM (voltage regulation module) as water flows directly over these critical areas, thus allowing the graphics card and it’s VRM to remain stable under high overclocks.
EK-FC R9 Nano water block features EK unique central inlet split-flow cooling engine design for best possible cooling performance. Such system also works flawlessly with the reversed water flow without adversely affecting the cooling performance. Moreover, such design offers great hydraulic performance, allowing this product to be used in liquid cooling systems using weaker water pumps. Unlike the original cooling solution with a single 90mm fan that comes with AMD Radeon R9 Nano and takes up two slots, EK-FC R9 Nano water block will transform the R9 Nano into a stunningly beautiful single-slot graphics card! EK encloses a single-slot I/O bracket which replaces the original two-slot in order to make installation of multiple graphics cards easier.
The base is made of electrolytic nickel-plated copper, while the top is made of either acrylic- or POM Acetal material, depending on the variant. Plexi variants also feature two pre-drilled slots for 3mm LED diodes. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure.
Additionally the EK-FC R9 Nano has been engineered with FC Terminal connection ports for up to four R9 Nano’s on a single ATX form factor motherboard, thus allowing for trouble-free swap out and upgrade without any additional changes to the cooling loop.
In order to simplify the search for suitable and compatible water block EK is adding newly released graphics cards and motherboards from various manufacturers to EK Cooling Configurator database and compatible graphics cards are being added to the list on a daily basis:
These water blocks are made in Slovenia, Europe and will be available for purchase through EK Webshop and Partner Reseller Network on Wednesday, September 23rd, 2015. An aesthetic retention backplate, which also cools the backside of the circuit board, will also be available for separate purchase and will come in a beautiful black variant.
You can join the discussion on EKWB’s R9 Nano Water block on the OC3D Forums.
