EVGA reveals its range of GeForce RTX 3080 Ti and RTX 3070 Ti graphics cards
EVGA’s ready to launch a new series of Nvidia RTX graphics card, having prepared a wide range of new RTX 3080 Ti and RTX 3070 Ti graphics cards, both of which offer gamers more CUDA cores than their non-Ti counterparts and more memory bandwidth.
With Nvidia’s RTX 3080 Ti, EVGA’s stressing the graphic’s card’s 12GB frame buffer, highlighting the GPU’s 20% boost in both memory bandwidth and memory capacity. With the RTX 3070 Ti, EVGA’s also boasting an almost doubling of I/O data rate, which could become a big deal for future memory-intensive games.
Like other RTX 30 series graphics cards, Nvidia’s RTX 3080 TI and RTX 3070 Ti offer PC gamers Nvidia’s 2nd generation RT cores and 3rd generation Tensor cores, delivering gamers more ray tracing throughout and stronger AI computational capabilities. In addition to this, Nvidia’s latest SM design has enabled a 2x boost in FP32 throughput, which is a big deal for many workstation/productivity applications.
For Nvidia’s RTX 3080 Ti, EVGA has six custom GPU models on the horizon, which included two air-cooled models, the FTW3 and IC3, two AIO-liquid-cooled models, the FTW3 Hybrid and XC3 Hybrid, and two custom water-cooled models called the FTW3 Hydro Copper and the XC3 Hydro Copper.
All of these graphics cards are similar to their RTX 3080 counterparts, albeit with the RTX 3080 Ti’s updated core and memory specifications.
For Nvidia’s RTX 3070 Ti, EVGA has two new models in the works, an FTW3 model and an XC3 version. Both of these designs will be similar to EVGA’s existing RTX 3070 counterparts but enable higher performance levels thanks to the RTX 3070 Ti’s higher-end specifications.
More information about Nvidia’s RTX 3070 Ti and RTX 3080 Ti is available here.
Nvidia plans to launch their RTX 3080 Ti graphics card on June 3rd and their RTX 3070 Ti on June 10th. The full specifications of these graphics cards are available below.
You can join the discussion on EVGA’s RTX 3080 Ti and RTX 3070 Ti graphics cards on the OC3D Forums.
