Gainward’s RTX 3090 and 3080 Phoenix GPUs leak – Specs and Pictures
Gainward's RTX 3090 and 3080 Phoenix GPUs leak - Specs and Pictures
On September 1st, Nvidia is due to officially reveal its RTX 30 series of Ampere powered graphics cards, the company’s first consumer-grade 7nm GPUs. Now, leaks for the series are appearing everywhere, with Gainward’s RTX 3090 and RTX 3080 Phoenix graphics cards being the latest to appear online, courtesy of Videocardz.
With Gainward’s RTX 3090 and 3080 Phoenix designs, the company plans to offer its customers a 2.7-slot design with a black and silver colour scheme, highlighting their units with RGB lighting. Both designs are triple fan models, and feature coolers which are longer than the PCBs of their graphics cards.
Gainward’s RTX 3090 Phoenix will feature 5248 CUDA cores, boost clock speeds of 1725MHz and 24GB of GDDR6X memory at 19.5 Gbps speeds. Their RTX 3080 Phoenix model will feature 4352 CUDA cores, boost clock speeds of 1740MHz and 10GB of GDDR6X memory at 19 Gbps speeds. These speeds make Gainward’s models slightly faster than Nvidia’s already leaked RTX 3000 Founders Edition models.
Gainward's RTX 3090 and 3080 Phoenix GPUs leak - Specs and Pictures  Gainward's RTX 3090 and 3080 Phoenix GPUs leak - Specs and Pictures
Below are the specifications of Gainward’s Phoenix RTX 3090 and 3080 Golden Sample models when compared to Nvidia’s Founders Edition models. The data in the chart below comes from data leaks and may be inaccurate.
  RTX 3090 FE RTX 3090
Phoenix GS
RTX 3080 FE RTX 3080
Phoenix GS
RTX 2080 Ti FE RTX 3070 FE
GPU GA102-300 GA-102-300 GA102-200 GA102-200 TU102-300 GA104-300
Node 7nm 7nm 7nm 7nm 12nm 7nm
CUDA Cores 5248 5248 4352 4352 4352 ?
Boost Clock 1695MHz 1725MHz 1710MHz 1740MHz 1635MHz ?
Memory 24GB GDDR6X 24GB GDDR6X 10GB GDDR6X 10GB GDDR6X 11GB GDDR6 8GB GDDR6
Memory Clock 19.5 Gbps 19.5 Gbps 19 Gbps 19 Gbps 14 Gbps 16 Gbps
Memory Bus 384-bit 384-bit 320-bit 320-bit 354-bit 256-bit
Bandwidth 936 GB/s 936 GB/s 760 GB/s 760 GB/s 616 GB/s 512 GB/s
TGP 350W 350W 320W 320W 260W 220W
You can join the discussion on Gainward’s RTX 3090 and RTX 3080 Phoenix custom models on the OC3D Forums.
