Geforce RTX 3060 Ti Eagle pictured
Thanks to Videocardz, we have a first look at Gigabyte’s RTX 3060 Ti Eagle model, revealing a dual-fan graphics card design that’s much smaller than the company’s RTX 3070 models.
According to previous rumours, Nvidia has delayed the launch of its RTX 3060 Ti until December 2nd, after AMD’s planned release date for their RX 6000 series of graphics cards.
With their RTX 3060 Ti design, Nvidia is bringing Ampere to lower TDP ranges. The RTX 3060 Ti is rumoured to offer users a TDP of 180W, which is 40 watts lower than Nvidia’s RTX 3070. This TDP shift is why Gigabyte has been able to offer this graphics card with a smaller dual-fan cooler design, unlike the company’s higher-end Eagle modes.
At this time, Nvidia has not officially revealed their RTX 3060 Ti graphics card, though it is rumoured to deliver RTX 2080 Super-like performance and release with MSRP pricing of under £400. Below are Nvidia’s rumoured RTX 3060 Ti specifications, and how they compare to the company’s other Ampere series graphics cards.
  RTX 3090  RTX 3080 RTX 3070 Leaked RTX 3060 Ti
Node 8nm 8nm 8nm 8nm
CUDA Cores 10496 8704 5888 4864
Base Clock 1.4 GHz 1.44 GHz 1.5 GHz 1.41 GHz
Boost Clock 1.7 GHz 1.71 GHz 1.73 GHz 1.665 GHz
Single-Precision
Performance
35.7 TFLOPS 29.8 TFLOPS 20.4 TFLOPS 16.2 TFLOPS
Memory 24GB GDDR6X 10GB GDDR6X 8GB GDDR6 8GB GDDR6
Memory Speed 19.5 Gbps 19 Gbps 14 Gbps 14 Gbps
Memory Bus 384-bit 320-bit 256-bit 256-bit
TGP 350W 320W 220W 180W
NVLINK Supported – – –
Pricing (US) $1,499 $699 $499 Sub-$400
Pricing (UK) £1,399 £649 £469 Sub-£400
You can join the discussion on Gigabyte’s RTX 3060 Ti Eagle on the OC3D Forums.
