Gigabyte launch their GTX 1080 Ti Aorus Waterforce Extreme Edition
According to Videocardz, this GPU will come with an impressive factory overclock of 10% on the GPU core and a 4% memory overclock. This new GPU will come with a 12+2 phase power design and dual 8-pin power connectors, coming with two HDMI 2.0 connections, three DisplayPort 1.4 connections and a single DVI-D port on its rear IO. Thanks to Gigabyte’s VR-Link technology this GPU also has a single HDMI 2.0 connection on the rear of the card, which is usable with case-mounted HDMI port passthrough.
At this time it is unknown who manufactures Gigabyte’s water block design, as there is no manufacturers logo in sight. The water block also features RGB LED illumination, which can be customised by the user.
| GTX 1080 Ti Founders Edition | Gigabyte GTX 1080 Ti Aorus Waterforce Extreme Edition | |
| GPU Architecture | Pascal | Pascal |
| Process node | 16nm | 16nm |
| SM Units | 56 | 56 |
| Cores per SM | 64 | 64 |
| CUDA Core Count | 3584 | 3584 |
| ROPs | 88 | 88 |
| VRAM Type | GDDR5X | GDDR5X |
| Memory Clock | 11008MHz | 11448MHz |
| VRAM Cappacity | 11GB | 11GB |
| Memory Bus Size | 352-bit | 352-bit |
| Base clock speed | 1480MHz | 1632MHz |
| Boost clock speed | 1582MHz | 1746MHz |
| Power Connection |
1x 8-pin 1x 6-pin |
2x 8-pin |
| PCI Express | PCIe 3.0 | PCIe 3.0 |
You can join the discussion on Gigabyte’s GTX 1080 Ti’s Aorus Waterforce Extreme Edition on the OC3D Forums.
