It’s true; some AIB Geforce RTX 2080 GPUs will be slower than Nvidia’s Founders Edition
It's true, some AIB Geforce RTX 2080 GPUs will be slower than Nvidia's Founders Edition
With the release of their RTX 20 series of Turing graphics cards, Nvidia has challenged their AIB partners by releasing Founders Edition graphics cards with factory overclocks.
This change places Nvidia’s Founders Edition offerings above the company’s reference specifications for the first time, allowing AIB manufacturers to release custom RTX series graphics cards with lower clock speeds than Nvidia’s home-grown models. For the first time, custom Nvidia graphics cards could offer less performance than Nvidia’s Founders Edition variants.
Zotac has officially confirmed the specifications of their Gaming RTX 2080 Blower graphics card, adhering to Nvidia’s reference specifications with a boost clock speed of 1710MHz while using a blower-style cooler. By sticking to Nvidia’s reference design, Zotac has created an RTX 2080 that offers a boost clock speed that is 90MHz lower than Nvidia’s Founders Edition, which in conjunction with it’s blower-style cooler will supply decreased performance, higher thermals under load and will likely run a lot louder than Nvidia’s RTX 2080 Founders Edition.
  Geforce RTX 2080 (FE) Zotac Gaming RTX 2080 Blower  Geforce RTX 2080 (Ref)
Architecture Turing Turing Turing
CUDA Cores 2,944 2,944 2,944
Ray Tracing Performance 8 Gigarays 8 Gigarays 8 Gigarays
Base Clock
1515MHz – 1515MHz
Boost Clock 1800MHz 1710MHz 1710MHz
Memory Type GDDR6 GDDR6 GDDR6
Memory Capacity 8GB 8GB 8GB
Memory Speed 14Gbps 14Gbps 14Gbps
Memory Bandwidth 448GB/s 448GB/s 448GB/s
Memory Bus Size 256-bit 256-bit 256-bit
SLI Via NVLink Via NVLink Via NVLink
Many aspects of Zotac’s Gaming RTX 2080 Blower remains consistent with Nvidia’s Founders Edition model, from its 8+6-pin power configuration to its included display outputs. The graphics card also appears to be using Nvidia’s reference PCB design, which is common to almost all blower-style graphics cards.
You can join the discussion on Zotac Gaming RTX 2080 Blower on the OC3D Forums.
