MSI Releases their First RX 590 Graphics Cards
This graphics card is powered using a single 8-pin PCIe power connector, just like most other RX 590 graphics cards and ships with both overclocked and reference speed variants, though both models offer end users the same PCB and cooler designs. AMD’s RX 590 GDDR5 memory specifications also remain unchanged, giving this model little to differentiate itself from its peers.
At this time MSI has not revealed the pricing of their RX 590 graphics card, though it is expected to ship with similar pricing to existing RX 590 graphics card models. Below are the specifications of MSI’s RX 590 series graphics cards, as well as AMD’s reference specifications for comparison purposes.
| AMD RX 590 (Reference) | MSI RX 590 ARMOR 8GB |
MSI RX ARMOR 8GB OC |
| Stream Processors | 2304 | 2304 | 2304 |
| Core Base Frequency | 1469MHz | – | – |
| Core Boost Frequency | 1545MHz | 1545MHz | 1565MHz |
| Memory Type | GDDR5 | GDDR5 | GDDR5 |
| Memory Bus | 256-bit | 256-bit | 256-bit |
| Memory Speed | 8000MHz | 8000MHz | 8000MHz |
| Memory Bandwidth | 256GB/s | 256GB/s | 256GB/s |
On the display output side, MSI’s RX 590 ARMOR ships with two HDMI 2.0 outputs, a single DVD-D connection and a single DisplayPort 1.4 port.
You can join the discussion on MSI’s RX 590 ARMOR graphics card on the OC3D Forums.
