Nanoxia announce their new CoolForce 2 chassis
Nanoxia announce their new CoolForce 2 chassis, a case designed with water cooling in mind with Green LED illumination built into the chassis. The chassis is designed as an entry level water cooling chassis, with enough space for a 360mm at the top of the case and enough space for a 240mm radiator at the front.
The case uses the almost standard Nanoxia Green colouring for its fans and LED illumination, making this case seem very suitable for an Nvidia themed system, or for use with a Gigabyte Green Sniper Series motherboard.
From the front of the case you can see that the Green LED Illumination for the case shines through, offering some subtle green illumination, which alongside the Green Nanoxia logo is very visually striking. Hopefully users who are not a fan of green will be able to remove and replace the LED strips in this case, perhaps allowing users to take advantage of some of the recently released RGB lighting kits from NZXT and CableMod.
Like many Nanoxia’s older products Coolforce 2 is designed to operate in silence, with noise reducing materials lining the cases side panels and the cases use of a modular Air Cover on the top of the chassis, which can be removed by the user if they are using top mounted radiators or fans.
The case is designed to be suitable for almost any hardware configuration, supporting two 5.25″ drive bays, 4 3.25″ hard drives and up to 6 2.5″ hard drives or SSDs. Below are the full specifications of the chassis.
This case should be hitting store shelves at the price of €84.99 next week, but is currently available to preorder in the EU from PC-Cooling.de.
You can join the discussion on Nanoxia’s Coolforce 2 chassis on the OC3D Forums.
Nanoxia announce their new CoolForce 2 chassis, a case designed with water cooling in mindhttps://t.co/qMUIiqiH2d pic.twitter.com/cqcgrxcH6x
— OC3D (@OC3D) March 11, 2016
