Nvidia reveals the specifications of their Geforce RTX 2080 Ti, RTX 2080 and RTX 2070
When Nvidia officially announced their Geforce RTX series of graphics cards, they spent little time talking about their specifications in detail, aside from references to their respective Ray Tracing performance.
Sadly, these specifications can only provide us with a limited amount of detail, as Nvidia’s new Turing SM units are said to increase their performance in ways outside of traditional clock speed boosts, making normal TFLOPS-to-TFLOPS comparisons inaccurate. Nvidia has also revealed no performance comparisons outside of Ray Traced applications, again giving gamers limited data with regards to real-world performance within today’s gaming workloads.
Nvidia’s website also reveals little detail regarding the AI/Tensor performance of their Geforce Turing graphics cards, again leaving gamers without exact information.
Alongside their Turing announcement, Nvidia also confirmed that their Turing series graphics cards would be moving away from traditional SLI bridges, replacing them with NVLink, which provides connected GPUs with a higher bandwidth connection that is suitable for higher resolutions and framerates. Nvidia’s NVLink bridges will cost £75 each in the UK and can span either three or four PCIe slots.
Unlike previous XX70 series models, Nvidia has opted to release their RTX 2070 without SLI/NVLink support, removing Multi-GPU support.
Nvidia Founders Edition Graphics  Geforce RTX 2080 Ti Geforce GTX 1080 Ti Geforce RTX 2080 Geforce GTX 1080  Geforce RTX 2070
Geforce GTX 1070 Ti Geforce GTX 1070
Architecture Turing Pascal Turing Pascal Turing Pascal Pascal
CUDA Cores 4,352 3584 2944 2560  2304 2432 1920
Tensor Cores ??? N/A ??? N/A ??? N/A N/A
Ray Tracing Performance 10 Gigarays – 8 Gigarays – 6 Gigarays – –
Base Clock
1350MHz 1481MHz 1510Mhz 1607MHz 1410MHz 1607MHz 1506MHz
Boost Clock 1635MHz 1582MHz 1800MHz 1733MHz 1710MHz 1683MHz 1683MHz
Memory Type GDDR6 GDDR5X GDDR6 GDDR5X GDDR6 GDDR5 GDDR5
Memory Capacity 11GB 11GB 8GB 8GB 8GB 8GB 8GB
Memory Speed 14Gbps 11Gbps 14Gbps 10Gbps 14Gbps 8Gbps 8Gbps
Memory Bandwidth 616GB/s 484GB/s 448GB/s 320GB/s 448GB/s 256GB/S 256GB/s
Memory Bus Size 352-bit 352-bit 256-bit 256-bit
256-bit 256-bit 256-bit
SLI Via NVLink SLI Via NVLink SLI N/A SLI SLI
Nvidia’s RTX 20 series graphics cards are already available to pre-order within the UK, pricing info is available here.
You can join the discussion on Nvidia’s RTX 2080 Ti, 2080 and 2070 specifications on the OC3D Forums.
