Nvidia releases their Geforce 417.22 driver for Battlefield V
Nvidia has officially released their Geforce 417.22 driver, which comes with new optimisations for RTX/DXR Raytracing in Battlefield V, and a new 3D vision profiles for Just Cause 4 and Project Nova.
This driver does not list “Game Ready” optimisations for Just Cause 4, which releases tomorrow, placing them behind AMD on the game-specific optimisations front. We will see soon enough whether or not this gives AMD/Radeon a performance advantage within the game.
What’s New in Version 417.22 WHQL
Game Ready Drivers provide the best possible gaming experience for all major new releases, including Virtual Reality games. Prior to a new title launching, our driver team is working up until the last minute to ensure every performance tweak and bug fix is included for the best gameplay on day-one.
Game Ready
Provides the optimal gaming experience for Battlefield V Tides of War Chapter 1: Overture Update.
3D Vision Profiles
Added or updated the following 3D Vision profiles:
• Just Cause 4 – Good
• Project Nova – Good
• Tom Clancy’s The Division 2 – Not recommended
Software Module Versions
• nView – 149.34
• HD Audio Driver – 1.3.38.4
• NVIDIA PhysX System Software – 9.18.0907
• GeForce Experience – 3.16.0.122
• CUDA – 10.0
Changes and Fixed Issues in Version 417.22
The following sections list the important changes and the most common issues resolved in this version. This list is only a subset of the total number of changes made in this driver version. The NVIDIA bug number is provided for reference.
Fixed Issues in this Release
– Display corruption may occur on higher refresh rate DisplayPort monitors upon resume from sleep mode. [2438988]
– [NVIDIA Control Panel]: Incorrect overclocked memory clock is reported. [200344681]
– [NVIDIA Control Panel]: Incorrect Memory Data Rate is reported. [2451378]
– [NVIDIA Control Panel]: RGB color format does not get set correctly even when forced in the NVIDIA Control Panel. [2451084]
– [Geforce RTX 2080 Ti][Hellblade Senua’s Sacrifice]: The game crashes. [2438363]
– [Microsoft Edge]: The browser does not respond after playing a video. [2451173]
– [BenQ ZOWIE XL2730]: The display shows a black screen when the refresh rate is set to 144 Hz. [2400008]
Open Issues in Version 417.22 WHQL
As with every released driver, version 417.22 WHQL of the Release 415 driver has open issues and enhancement requests associated with it. This section includes lists of issues that are either not fixed or not implemented in this version. Some problems listed may
not have been thoroughly investigated and, in fact, may not be NVIDIA issues. Others
may have workaround solutions.
For notebook computers, issues can be system-specific and may not be seen on your particular notebook.
Windows 10 Issues
– [SLI][TITAN Xp]: SLI is disabled by default after installing the driver. [200471881]
– [GeForce GTX 1080Ti]: Random DPC watchdog violation error when using multiple GPUs on motherboards with PLX chips. [2079538]
– [Firefox]: Cursor shows brief corruption when hovering on certain links in Firefox. [2107201]
– [G-Sync]: Random flickering occurs when connecting G-sync monitor + non-G-Sync HDMI monitor with G-Sync enabled. [2399845]
– [TITAN V][NVIDIA Control Panel]: The Workstation->Manage GPU Utilization page appears when it shouldn’t. [200470813]
Product Compatibility
Nvidia RTX 20 series
Geforce RTX 2080 Ti, Geforce RTX 2080, Geforce RTX 2070
NVIDIA TITAN Series
NVIDIA TITAN V, NVIDIA TITAN Xp, NVIDIA TITAN X (Pascal), GeForce GTX TITAN, GeForce GTX TITAN X, GeForce GTX TITAN Black, GeForce GTX TITAN Z
GeForce 10 Series
GeForce GTX 1080 Ti, GeForce GTX 1080, GeForce GTX 1070 Ti, GeForce GTX 1070, GeForce GTX 1060, GeForce GTX 1050 Ti, GeForce GTX 1050, GeForce GT 1030
GeForce 900 Series
GeForce GTX 980 Ti, GeForce GTX 980, GeForce GTX 970, GeForce GTX 960, GeForce GTX 950
GeForce 700 Series
GeForce GTX 780 Ti, GeForce GTX 780, GeForce GTX 770, GeForce GTX 760, GeForce GTX 760 Ti (OEM), GeForce GTX 750 Ti, GeForce GTX 750, GeForce GTX 745, GeForce GT 740, GeForce GT 730, GeForce GT 720, GeForce GT 710
GeForce 600 Series
GeForce GTX 690, GeForce GTX 680, GeForce GTX 670, GeForce GTX 660 Ti, GeForce GTX 660, GeForce GTX 650 Ti BOOST, GeForce GTX 650 Ti, GeForce GTX 650, GeForce GTX 645, GeForce GT 640, GeForce GT 635, GeForce GT 630
417.22 WHQL Download Links
Windows 10 – 64 Bit
Windows 7 – 64-Bit
You can join the discussion on Nvidia’s new Geforce 417.22 WHQL driver on the OC3D Forums.
