Nvidia’s reportedly creating a 20GB RTX 3080 Ti to combat AMD’s Radeon RX 6900 XT
Nvidia's may be preparing an RTX 3080 Ti to combat the Radeon RX 6000 series.
Rumour has it that Nvidia’s working on an RTX 3080 Ti graphics card, a new Ampere SKU which will act as a new competitor to AMD’s upcoming RX 6900 XT graphics card.
According to @koptite7kimi on Twitter, Nvidia has been testing a new graphics card design which features 10,496 CUDA cores, 20GB of GDDR6X memory and the same TDP as Nvidia’s RTX 3080.
This new graphics card is expected to target the $999 price point, offering users 4GB less memory than an RTX 3090, slightly slower memory speeds over a smaller 320-bit memory bus and a lower power target than an RTX 3090. Given these specifications, Nvidia’s RTX 3080 Ti will sit between Nvidia’s RTX 3080 and RTX 3090 models, graphics cards which already feature a slim performance gap.
If these reported RTX 3080 Ti specifications are correct, Nvidia will have made their RTX 3090 graphics card practically irrelevant to the wider consumer market. For most users, the RTX 3090’s additional VRAM, memory bandwidth and higher power target will be ok little consequence, as will the GPU’s lack of NVLINK support.
  RTX 3090  Rumoured RTX 3080 Ti RTX 3080 RTX 3070 Leaked RTX 3060 Ti
Node 8nm 8nm 8nm 8nm 8nm
CUDA Cores 10496 10496 8704 5888 4864
Base Clock 1.4 GHz ?? 1.44 GHz 1.5 GHz 1.41 GHz
Boost Clock 1.7 GHz ?? 1.71 GHz 1.73 GHz 1.665 GHz
Single-Precision
Performance
35.7 TFLOPS ?? 29.8 TFLOPS 20.4 TFLOPS 16.2 TFLOPS
Memory 24GB GDDR6X 20GB GDDR6 10GB GDDR6X 8GB GDDR6 8GB GDDR6
Memory Speed 19.5 Gbps 19 Gbps 19 Gbps 14 Gbps 14 Gbps
Memory Bus 384-bit 320-bit 320-bit 256-bit 256-bit
TGP 350W 320W 320W 220W ??
Recommended PSU 750W 750W 750W 650W ??
NVLINK Supported – – – –
Pricing (US) $1,499 ?? $699 $499 ??
Pricing (UK) £1,399 ?? £649 £469 ??
AMD’s Radeon RX 6000 series is due to launch as strong competitors to Nvidia’s Ampere lineup, injecting some much-needed competition into the GPU market. Competition could get even tighter in 2021, as Intel plans to enter the discrete graphics market.
You can join the discussion on Nvidia’s rumoured RTX 3080 Ti graphics card on the OC3D Forums.
