PowerColor reveals its Radeon RX 5600 XT Red Devil with 14Gbps GDDR6 memory
PowerColor’s Red Devil series of graphics cards are designed to deliver top-tier performance levels for its respective GPU model; packing factory overclocks which stand above the norm for AMD’s other Add-In-Board (AIB) partners.
In the case of the Radeon RX 5600 XT, PowerColor’s Red Devil model offers gamers both a graphics core overclock and faster GDDR6 memory, changes which will boost the graphics cards performance in terms of both computation and memory bandwidth.
With a 1660MHz game clock and a 1750MHz boost clock, PowerColor’s RX 5600 XT Red Devil will offer core clock speeds that are higher than AMD’s reference RX 5700, making PowerColor’s highest-end RX 5600 XT more computationally powerful. While the RX 5600 XT still offers less memory bandwidth than AMD’s RX 5700 series, due to its smaller memory bus, PowerColor’s Red Devil model’s higher-speed GDDR6 memory should help close this bandwidth gap.
Below are the specifications of AMD’s reference RX 5000 series graphics cards, and PowerColor’s RX 5600 XT Red Devil. Based on what we can see below, PowerColor’s RX 5600 XT should be a lot more powerful than AMD’s reference RX 5600 XT models.
Like PowerColor’s other Red Devil series graphics cards, PowerColor’s RX 5600 XT Red Devil will feature a dual BIOS, offering users a switch which will allow the graphics card to run in either “Silent” or “Overclocked” modes.
  AMD RX 5500 XT AMD RX 5600 XT PowerColor RX
5600 XT Red Devil
AMD RX 5700 AMD RX 5700 XT
Process Tech/ Architecture 7nm Navi 7nm Navi 7nm Navi 7nm Navi 7nm Navi
Stream
Processors
1408 2304 2304 2304 2560
Base Clock  – – – 1465MHz 1605MHz
Gaming Clock 1717MHz 1375MHz 1650MHz 1625MHz 1755MHz
Boost Clock 1845MHz 1560MHz 1750MHz 1725MHz 1905MHz
Memory 4/8GB GDDR6 6GB GDDR6 6GB GDDR6 8GB GDDR6 8GB GDDR6
Memory Bus 128-bit 192-bit 192-bit 256-bit 256-bit
Memory Clock 14Gbps 12Gbps 14Gbps 14Gbps 14Gbps
Memory
Bandwidth
224GB/s 288GB/s 336GB/s 448GB/s 448GB/s
MSRP (US) $169 $279 ??? $349 $399
You can join the discussion on PowerColor’s Radeon RX 5600 XT Red Devil graphics card on the OC3D Forums.
