RX 500 reference clock speeds and specifications have been leaked
| RX 580 | RX 480 | RX 570 | RX 470 | |
| GPU Cores | 2304 | 2304 | 2048 | 2048 |
| Base Clock | 1257MHz | 1120MHz | 1168MHz | 926MHz |
| Boost Clock | 1340MHz | 1266MHz | 1244MHz | 1206MHz |
One of the most interesting changes in this new series will be with the RX 560, which will feature both higher clock speeds and more GPU cores than their RX 460, giving it much more performance.
We also have the new RX 550, which will come with only 512 GPU cores and will likely be priced below £80 as an affordable replacement for integrated graphics solutions.
| RX 560 | RX 460 | RX 550 | |
| GPU Cores | 1024 | 896 | 512 |
| Base Clock | 1175MHz | 1090MHz | – |
| Boost Clock | 1275MHz | 1200MHz | 1183MHz |
| Memory bus | 128-bit | 128-bit | 128-bit |
These leaked slides did not include any pricing information for these new GPUs, though we expect them to all be priced a little higher than their RX 400 series counterparts.
You can join the discussion on AMD’s RX 500 series specifications on the OC3D Forums.
