Sapphire launches their Radeon RX 5700 Pulse series of Graphics Cards
With its PULSE series of Navi graphics cards, Sapphire is offering its users a Dual-X cooling solution with replaceable quick-connect fans, offering superior thermals to AMD’s reference cooling solution while also allowing users to replace their fans with ease in the event of damage. This makes the Radeon 5700 Pulse’s RMA process a lot easier.
Both the RX 5700 Pulse and RX 5700 XT Pulse are available starting today in the UK, shipping with prices of £364.99 and £424.99 at Overclockers UK respectively. Below are the specifications of Sapphire’s RX 5700 Pulse series of graphics cards. Please note that higher-end models are expected from Sapphire in the future, likely in the form of a Nitro+ model.
Both RX 5700 Pulse models ship with 8+6-pin power config, with Sapphire recommending a 600W power supply at a minimum.
| Sapphire RX 5700 XT PULSE | AMD RX 5700 XT 50th | AMD RX 5700 XT | SAPPHIRE RX 5700 PULSE | AMD RX 5700 | |
| Process Tech/ Architecture | 7nm Navi | 7nm Navi | 7nm Navi | 7nm Navi | 7nm Navi |
| Stream Processors |
2560 | 2560 | 2560 | 2304 | 2304 |
| Base Clock | 1670MHz | 1680MHz | 1605MHz | 1540MHz | 1465MHz |
| Gaming Clock | 1815MHz | 1830MHz | 1755MHz | 1700MHz | 1625MHz |
| Boost Clock | 1925MHz | 1980MHz | 1905MHz | 1750MHz | 1725MHz |
| Memory | 8GB GDDR6 | 8GB GDDR6 | 8GB GDDR6 | 8GB GDDR6 | 8GB GDDR6 |
| Memory Bus | 256-bit | 256-bit | 256-bit | 256-bit | 256-bit |
| Memory Clock | 14Gbps | 14Gbps | 14Gbps | 14Gbps | 14Gbps |
| Memory Bandwidth |
448GB/s | 448GB/s | 448GB/s | 448GB/s | 448GB/s |
You can join the discussion on Sapphire’s Radeon RX 5700 Pulse series of graphics cards on the OC3D Forums.
