Specs for AMD’s Radeon RX 5700 XT and RX 5700 have leaked
Specs for AMD's Radeon RX 5700 XT and RX 5700 have leaked
The specifications of AMD’s Radeon RX 5700 XT and Radeon RX 5700 have leaked online, revealing that the Radeon RX 5700 is basically a Navi-based version of AMD’s Radeon RX 590/580 series cards, offering the same number of stream processors but with the benefits of Radeon’s Navi architecture, higher core clock speeds and GDDR6 memory.
AMD has claimed that their Navi/RDNA graphics architecture offers a 25% increase in IPC over the company’s last-generation offerings, which when combined with higher core clock speeds will deliver gamers greater than 25% performance improvements in gaming performance per stream processor, which is an incredible generation over generation performance leap.
Videocardz has also reported that AMD is offering its users an improved video encoder/decoder with Navi as well as a new multilevel cache structure, improved delta colour compression (to deliver more effective memory bandwidth) and increased compute efficiency for a diverse selection of gaming and computational workloads.
  RX Vega 56 RX 5700XT (Leaked) RX 5700 RX 590 RX 580 RX 570
Process Tech and Architecture 14nm Vega 7nm Navi 7nm Navi 12nm Polaris 14nm Polaris 14nm Polaris
Stream Processors 3584 2560 2304 2304 2304 2048
Max FP32 Compute 10.5 TFLOPS 9.75 TFLOPS 7.95 TFLOPS 7,1 TFLOPS 6.2 TFLOPS 5.1 TFLOPS
Base Clock  1156MHz 1605MHz 1465MHz 1469MHz 1257MHz 1168MHz
Gaming Clock   1755MHz 1625MHz – – –
Boost Clock 1471MHz 1905MHz 1725MHz 1545MHz 1340MHz 1244MHz
Memory 8GB HBM2 8GB GDDR6 8GB GDDR6 8GB GDDR5 8GB GDDR5 4/8GB GDDR5
Memory Bus 2048-bit 256-bit 256-bit 256-bit 256-bit 256-bit
Memory Clock 800MHz 14Gbps 14Gbps 8Gbps 8Gbps 7Gbps
Memory Bandwidth 410GB/s 484GB/s 484GB/s 256GB/s 256GB/s 224Gbps
AMD Radeon RX 5700 XT Benchmarks Leak
All that’s unknown about AMD’s Navi series of graphics cards right now is their pricing, which will prove to be a critical factor as Navi approaches its launch this July.
You can join the discussion on AMD’s Radeon Navi RX 5700 XT and RX 5700 graphics cards on the OC3D Forums.
