EK simplifies Hardline Water Cooling with Pre-Bent EK-Loop Hard Loop Tubing
EK simplifies Hardline Water-Cooling with Pre-Bent EK-Loop Hard Loop Tubing
In an effort to make Acrylic Tubing more accessible to water cooling newcomers, EK Water Blocks has created a series of Hardline Acrylic Tubing that are pre-bent. This eliminates the need for users to purchase specialised acrylic tube bending and delivers consumers, saves users time, and offers users consistent bends on each of their hardline acrylic tubes.
What EK’s selling here is saved time and consistent tubing bends, which is great news for end-users. Better still, these tubes are acrylic, a material that is harder to heat/bend than more mainstream PETG tubing solutions. Acrylic boasts a more glass-like clarity than PETG and is less prone to discolouration, with the material’s only major downside being the challenges of heating/bending these tubes for custom liquid-cooling setups.
Several size options, perfect for newcomers
EK’s new series of pre-bent acrylic tubing comes with outer diameter options of 12mm, 14mm and 16mm, supporting all major hardline fitting types. These tubes ship with 800mm lengths, allowing users to shorten these tubes as needed to fit inside their systems. Please note that users will need to chamfer the edges of their acrylic tubing to prevent 0-ring damage and ensure a watertight fit.
Each pack of pre-bent acrylic Hard Tubes will come with six 0.8m pieces and will be made from acrylic. These tubing kits will not come with compatible fittings, though they will support hard tube push-in (HDP) and compression (HDC) fitting types.
While building a PC with hardline tubing will remain a challenge, EK’s selection of pre-bent acrylic hard tubes will greatly simplify the building process. That said, EK’s acrylic tubing kits are not cheap, adding more expense to PC liquid cooling setups.
Availability and Pricing
EK-Loop Hard Tube 12/14/16 mm 0.8 m Pre-Bent 90 – Acrylic is made in Germany, Europe. It is available for order through the EK Webshop and Partner Reseller Network. In the table below, you can see the manufacturer suggested retail price (MSRP) with VAT included.
– EK-Loop Hard Tube 12 mm 0.8 m Pre-Bent 90 – Acrylic (6pcs) 54.90€
– EK-Loop Hard Tube 14 mm 0.8 m Pre-Bent 90 – Acrylic (6pcs) 59.90€
– EK-Loop Hard Tube 16 mm 0.8 m Pre-Bent 90 – Acrylic (6pcs) 64.90€
For more information, visit this page.
You can join the discussion on EK’s pre-bent hardline liquid cooling tubing kits on the OC3D Forum.
