MSI launch their new WIFI 7 Roamii BE Lite Mesh System
MSI pushes WIFI 7 across your home with their new Roamii Mesh networking system
Wireless networking can often be a pain. Almost everyone has a place in their house where their WIFI doesn’t quite reach. Setting up your router in an “ideal” location isn’t always an option, and if that is possible, even that isn’t a guarantee of full household coverage. That’s where Mesh WIFI comes into play and where MSI steps in with their new Roamii BE Lite WIFI 7 Mesh System.
With Mesh WIFI, you can set up multiple nodes to ensure that your entire household gets access to fast WIFI. With MSI’s new Roamii BE Lite system, you can deliver ultra-fast WIFI 7 speeds across your home. It supports transfer speeds of up to 5 Gbps; each node also supports wired networking options. With two Gigabit and 1 2.5Gb wired connections on each node, each node can deliver fast wired connections or be used as a mesh backhaul.
MSI Roamii BE Lite Mesh System has dual-band WiFi 7 streams that support transfer speeds up to 5 Gbps. Each node also supports advanced WiFi 7 features like 4K-QAM, Multi-RU, and MLO (Multi-Link Operation). Users can also wall mount each Raomii node or place it wherever they wish. Each unit features a stylish white design that is triangular.
Users of MSI’s Roamii mesh systems can use the company’s Raomii app to configure their mesh nodes. Users can create separate networks for children, guests, and smart home devices to isolate devices. Parental controls are available through the Roamii app, and MSI’s Fortisecu feature allows mesh nodes to scan threats and protect connected devices from potential attackers.
More information about MSI’s new Raomii BE Lite Mesh System is available here.
You can join the discussion on MSI’s new WIFI 7 Raomii BE Lite Mesh system on the OC3D Forums.
