Sabrent reveals fast-charging USB Type-C cables with Smart Display tech
These new fast-charging cables from Sabrent let you know your device’s power draw at a glance
How fast are your devices charging. Are you making full use of the fast-charging capabilities of your devices, or is your charging limited? With these new fast-charging cables from Sabrent, you will finally know how fast your devices are charging, and if your are charging your devices as fast as possible.
With their new Smart Display Fast-Charging USB Type-C cables, Sabrent are allowing their customers to see how fast their devices are charging at a glance. While data transfer speeds are limited to USB 2.0 speeds, charging speeds can be as high as 100W. That’s perfect for smartphones, tablets, and laptops.
Alongside their USB Type-C to USB Type-C cable option, Sabrent has also created a fast-charging USB Type-C to Lightning cable. This cable also features Sabrent’s Smart Display, but it is limited to 60W charging. All of these new fast-charging cables are available in 1 meter and 2 meter lengths. All models are now available from Sabrent’s webstore.
While having a charging cable with an LED smart display may seem a little unnecessary, it is nice to see Sabrent thinking outside of the box with these cables. If you want to invest in fast-charging USB cables, you should always in cables from a good brand. After all, you don’t want your expensive smartphone or laptop to be ruined by a low quality cable.
You can join the discussion on Sabrent’s new Smart Display USB Type-C charging cables on the OC3D Forums.
