SilverStone Tek’s PI02 will keep your Raspberry Pi 4B cool and protected
SilverStone Tek's PI02 will keep your Raspberry Pi 4B cool and protected
SilverStone has officially revealed its new PI02 enclosure for Raspberry Pi 4B systems, offering these mini PCs the protection of a full aluminium enclosure as well as the improved heat dissipation offered by passive heatsinks.
With the PI02, SilverStone Tek allows users of the Raspberry Pi to wall mount their systems and benefit from lower thermals under sustained loads. SilverStone has quoted SOC temperatures that are often 10-degrees lower than a standard Raspberry Pi 4. Not bad for a passive heatsink design.
The PI02 also offers users dedicated cutouts for all ports on the Raspberry Pi 4B models and includes additional cutouts to support a WiFi Antenna and devices connected via GPIO ports.
Dedicated heatsinks are provided by the Raspberry Pi 4’s main SOC and USB 3.0 controller, providing dedicated cooling to the unit’s most power-hungry components. This heat is then transferred to the aluminium shell of the PI02, keeping the unit cool without active cooling. The enclosure measures in at 94.2 mm x 33.7 mm x 65 mm (WxHxD), and weighs 116 grams.
SilverStone has also confirmed that this case is wall mountable, allowing users to mount their Raspberry Pi 4 almost anywhere. Sadly, SilverStone has not revealed the pricing of this unit, though they are expected to arrive at retailers soon.
SilverStone Tek's PI02 will keep your Raspberry Pi 4B cool and protected  SilverStone Tek's PI02 will keep your Raspberry Pi 4B cool and protected
You can join the discussion on SilverStone Tek’s PI02 case for the Raspberry Pi 4B on the OC3D Forums.
