Thermal Grizzly WireView Pro II Pre-Orders Open
Thermal Grizzly’s new WireView Pro II is now available to pre-order – Safer 12V-2×6 power!
Thermal Grizzly has just opened pre-orders for their new WireView Pro II 12V-2×6/12VHPWR monitoring tool. This tool provides data analytics for users of 16-pin 12VHPWR and 12V-2×6 power connectors. Additionally, it adds new safety features that should prevent “cable melting” incidents.
With this new incarnation, Thermal Grizzly has delivered some welcome upgrades to their popular 16-pin power adapter. For starters, they have replaced the original OLED screen with a larger LCD. This allows more data to be showcased. Furthermore, the new model also features a small fan for cooling. The original WireView could run hot, especially when used with liquid-cooled GPUs. This was due to a lack of airflow. This added fan cools the device down. Furthermore, its CNC-machined aluminium housing acts as a heatsink.
Current sensing for all power pins
Another neat upgrade is the WireView PRO II’s ability to measure the current of each power pin on a 16-pin GPU power connector. This allows users to see if power is distributed evenly across their cable, a helpful safety measure.
The WireView Pro II has an automatic system shutdown feature
This is the most useful feature of Thermal Grizzly’s new 16-pin cable monitoring tool. It can be connected to your PC’s power button using a splitter cable and automatically shut down your PC if major issues are detected. This will prevent your GPU or power cables from burning, as it will detect dangerously uneven power delivery before heat can build up.
Thermal Grizzly’s new WireView Pro II is now available to pre-order on Thermal Grizzly’s webstore. This tool is available with “normal” and “reverse” cable alignments, allowing the tool to support almost all modern 12V-2×6-powered graphics cards.
- Thermal Grizzly WireView Pro II – €119.90 – Thermal Grizzly Webstore
You can join the discussion on Thermal Grizzly’s WireView Pro II on the OC3D Forums.
