Ethereum’s power-hungry days are numbered – Will Proof-of-Stake kill GPU mining?
Beyond its impact on the PC building ecosystem, cryptocurrency mining also has a huge environmental cost. The energy requires to operate the world’s cryptocurrency networks is staggering and can often be equivalent to that of nations, making cryptocurrencies an ecological disaster, outside of the rare cases where these currencies are mined using renewable energy sources.
The Ethereum Foundation has a solution to this problem, removing the need for cryptocurrency mining and creating an ecosystem where nation-scale power requirements are eliminated. Proof-of-Stake (POS) is coming to Ethereum, and it will kill GPU mining. “Ethereum will be completing the transition to Proof-of-Stake in the upcoming months”, claims the Ethereum Foundation.
While other cryptocurrencies will remain minable, Ethereum’s mining profitability is what’s fueling today’s mining boom. Ethereum is now due to move to a POS system, removing the world’s most profitable mining currency from the mining ecosystem.
With Proof of Stake, the Ethereum Foundation has predicted that they will be able to eliminate 99.95% of Ethereum’s energy use, delivering a 2000x increase in network efficiency. Assuming that Ethereum’s POS network is secure and stable, this paints a brighter, greener future for the cryptocurrency.
The short answer is that it’s complicated. Ethereum may be the most profitable Proof-of-Work (minable) cryptocurrency out there, but it is not the only one. Ethereum’s move to Proof-of-Stake will drastically reduce the profitability of cryptocurrency mining, but it will not end cryptocurrency mining in its entirety.
PC gamers should expect a reduction in hardware demand from cryptocurrency miners once Ethereum moves to a Proof-of-Stake system, but that doesn’t mean that miners will no longer see gaming GPUs as a desirable purchase. This change should help to increase GPU availability for gamers, but that doesn’t mean that mining-related shortages will never happen again.
You can join the discussion on Ethereum’s transition to Proof-of-Stake on the OC3D Forums.
