AeroCool X-Predator Evil
The XPREDATOR Evil Black edition is a newly designed case from AeroCool, Wearing the Black PGS (Performance Gaming System) badge it forms part of their Ultimate Gaming Series range. The X-predator is available in 4 different colour combinations. Plain Black, Black with Green accents, White with Black accents, and lastly Black with Orange accents which is the “Evil Black” edition reviewed here.
Undeniably a full tower case, with some retailers dubbing it a Super tower. The case measures 600mm in height, being 234mm wide and 555mm deep. The case is able to take pretty much any Motherboard you care to throw at it, from ATX, up through EATX all the way up to the giddy heights of XL-ATX boards such as the Assassin and UD9.
Technical Specifications
| Case Type | Full Tower |
| Material | SECC 0.8/1.0mm |
| Compatible Motherboards | Flex ATX / ATX / Micro ATX / E-ATX / XL-ATX |
| Chassis Dimensions | 600(H) x 234(W) x 555(D) |
| Drive Bays | 6 x 5.25″ (External) / 6 x HDDs (internal) / 1 x 3.5″ (External) |
| Expansion Slots | 10 Slots |
| Max length space available for PCI cards | 330mm |
| I/O Ports | 1 x USB 3.0 / 3 x USB 2.0 / e-SATA / Mic & headphone (AC97 & HD audio) |
| Fan controller | Controls 6 fans simultaneously with max combined wattage of 20W |
| Cooling options | Front – 1 x 23cm fan Orange LED (included), Back – 1 x 12/14cm fan (optional), 4 x 12/14cm fans or / 1 x 18/20cm fan (optional), Top – 1 x 23cm fan (included), Bottom – 1 x 12/14cm fan (optional) |
| 200mm Fan Specs | |
| Rated voltage | 12V |
| Operating Voltage Range | 10.8 – 13.2V |
| Starting voltage | 8V |
| Rated Current | 0.15A +10% Max |
| Label Current | 0.24A |
| Locked Current | 0.24A +10% Max |
| Power Consumption Speed | 2.88W+10%Max |
| Fan speed | 750 ±100RPM |
| Max AirFlow | 49CFM |
| Max Static Pressure | 0.54mm-H2O |
| Noise | 27dBA |
| MTBF | 25,000/hrs |
| Warranty | 24 months |
| EAN barcode | 4710700956472 |
