AMD Ryzen 5 & 7 CPU Cooler Round Up
NZXT X62
The NZXT X62 is largest AIO liquid cooler that NZXt currently produces, coming with a 280mm radiator and two static pressure optimised 140mm fans.Â
With RGB illumination, a reflective pump top with a mirror shine and a large 280mm radiator, this cooler is designed to be a premium product, with this cooler being the most expensive cooler that we are testing today.Â
Â
Radiator:
– Dimensions (LxWxH)(mm): 315 x 143 x 30Â
– Material: Aluminum
– Weight: 1.29g
Pump & Water Block
– Dimensions (LxWxH)(mm): 80 x 80 x 52.9
– Material: Copper, Plastic
– Variable Pump Speed: 1,000 – 2,800 ± 300 RPM
– Pump Control: Silent/Performance/Custom/Manual
Fan
– Model: Aer P140 PWM Fan
– Quantity: 2 x 140mm
– Fan Modes: Silent/Performance/Custom/Manual
– Speed: 500-1,800 ± 300 RPM
– Noise: 21-38dBA
– Warranty: 6 Years
Â
Â
Â
AM4 Support
NZXT’s X52 does not support AMD’s AM4 socket out of the box, with NZXT providing AM4 mounting brackets to users who own NZXT Kraken series AIO. Â Â
(1) Visit https://www.nzxt.com/customer-support and submit a ticket.
(2)Â Choose âAM4 Bracket Supportâ as your department.
(3) Attach your Kraken series AIO liquid cooler proof of purchase.
(4) Attach your motherboard with AM4 socket proof of purchase.
Upon validation, the bracket will be shipped to you free of charge.Â
Â
Â
