AMD Ryzen 5 & 7 CPU Cooler Round Up
Corsair H115i V2
The H115i V2 is the bigger brother of Corsair’s popular H100i, coming with a 280mm radiator and two large 140mm fans. This cooler is designed for heavy overclocking, easily cooling overclocked X99 CPUs and keeping quiet under load while doing so.
Features:
– Large 280mm radiator: more cooling capacity for cases which have 280mm radiator mounts
– Improved coldplate and pump design: better efficiency gives you lower temperatures with less noise
– Advanced SP140L PWM fan design: better high-static pressure air delivery and customizable speed
– Built-in Corsair Link: monitor CPU and coolant temperature, adjust fan speed, and customize lighting directly from
your desktop
Box Contents:
– Corsair Hydro Series H115i Extreme Performance Liquid CPU Cooler
– Mounting kit for all modern CPU sockets
– Two SP140L High Torque 140mm fans
– USB cable for Corsair Link. Integration
– Fan and radiator mounting screws
– Thermal compound (pre-applied)
AM4 Compatability
Corsair’s H115i V2 is compatible with AMD’s AM4 socket, but the cooler will require an AM4 mounting bracket. This is available from Corsair for free for a limited time, though the company does allow users to purchase this bracket for £4.
You can fin out more about the AM4 compatibility of Corsair’s CPU coolers here.
