AMD Ryzen 5 & 7 CPU Cooler Round Up
AMD Ryzen 5 & 7 CPU Cooler Mega Test
Cryorig H7
The Cryorig H7 is a single tower CPU cooler which uses a 120mm fan and comes at an ultra-affordable price of £36.95, this cooler is a staple for budget builders, offering a three-year warranty and compatibility with all major CPU sockets.
This cooler does not come with an AM4 mounting kit out of the box, but Cryorig does provide this kit for free if users can provide proof of purchase or pictures of their cooler.
Heatsink Specification
– Dimension ( with fan ): L98 mm x W123 mm x H145 mm
– Weight ( with fan ): 711 g
– Weight ( without fan ): 577 g
– Heat pipes: 6mm heatpipe x 3 units
– Fin: T = 0.4 mm ; Gap = 2.2 mm
– Front Fin Pcs: 40 pcs
– Copper Base: C1100 Pure copper nickel plated
– RAM Tolerance Height: Limitless
– TDP: 140 W
Fan Specification:
– Dimension: L120 mm x W120 mm x H25.4 mm
– Weight: 134 g
– Rated Speed: 330 ~ 1600 RPM ±10 %
– Noise Level: 10 ~ 25 dBA
– Air Flow: 49 CFM
– Air Pressure: 1.65 mmH2O
– Ampere: 0.16 A
Current Price – £36.95
AM4 Compatability
A wide range of Cryorig coolers are compatible with AMD’s AM4 socket thanks to the companies AM4 upgrade bracket, this bracket is available free of charge to those that can provide proof or purchase for their Cryorig cooler and an AM4 CPU/motherboard.
Cryorig users can apply for a free upgrade bracket here.
   CRYORIG will provide all existing users and new owners of AMD supported products the new AM4 kit totally free of charge. Existing eligible products include: R1 Universal/Ultimate, C1, H5 Universal/Ultimate, H7, H7 Quad Lumi, M9a, C7, A40, A40 Ultimate and A80.
Users only need to the following information: proof of purchase of the CRYORIG product (or product registration number), and a proof of purchase of a AMD Ryzen or AM4 CPU. Just fill out and supply all necessary info at www.cryorig.com/getam4.php, the kit will be sent directly to the provided address. Local distributors and select channels will also have these kits available.
AMD Ryzen CPU Cooler Mega Test
Up Close
This cooler offers a compact design that has no problems with large memory kits on AM4, leaving plenty of space to replace memory kits or otherwise work inside out Corsair Air 240 chassis.
