Anidees AI Crystal Tempered Glass Case Review
Anidees AI Crystal Review
As we said on the home page, Anidees are billing the new AI as “not just a case with a glass side panel” (actually they left out the second “a” but it was bugging us so we put it back in), the effect though, is much the same.  They are though kinda right, this isn’t just a case with “A” glass side panels. it’s a case with two glass side panels and a glass front pane for that matterl, and it has to be said, looks simply stunning.  So stunning in fact that we donned a pair of white cotton gloves before handling it so as not to soil it with our greasy fingerprints.  We also dug out the Polaroid filter for the camera, otherwise all you would be seeing would be reflections of the junk that accumulates behind the photography area.  So what do we have here then, well in simple terms its a mid size tower that offers a range of motherboard support as well as rather impressive water cooling options.  If first impressions count, then the AI has made a good one, but let’s crack on and have a look at the all important Technical Specification
Dimensions 497x216x475mm (HxWxD)
Colour  Black with black smoked Glass
Materials Steel, 5mmTempered Glass
Motherboard support  M-ITX, M-ATX, ATX, E-ATX (12″x13″EEB)
Weight  10.9kg
5.25″  0
3.5″  3 (Hidden)
2.5″  3 (Hidden)
Front I/O  2xUSB3.0, 2xUSB2.0, Audio, 3 Speed fan controller
Air Cooling
Front:   3x140mm (3x120mm optional)
Roof:    3×140/120mm Optional
Rear:    1x140mm, (1x120mm Optional)
Water Cooling
Front:  Up to 360mm or 280mm (63mm clearance)
Roof:   Up to 360mm or 280mm (60mm clearance)
Rear:   120/140mm
Expansion Slots  7
Max CPU Cooler Height  175mm
Max GPU Length  410mm
