CoolerMaster MasterAir MA410M Review
Full RGB LED enabled Heat sinks are very “de rigueur” at the moment, (and yes we know that means the same thing), in fact so much so that’s it’s getting hard to find a new release that hasn’t been fully LED loaded.  Where we appreciate the ability to integrate our case lighting with the colour scheme of our build, it’s also important to us that the cooler does it’s primary job, which is that of keeping the CPU cool.  So with this in mind, let’s take a look at those all important Technical Specifications to see if we can tell how the MA410M is going to perform.
Dimensions  111.8×130.9×165.1mm
Material Aluminium funs
Intel  LGA 2066 / 2011-v3 / 2011 / 1151 / 1150 / 1155 / 1156  / 1366 socket
AMD  AM4 / AM3 / AM3 / AM2 / AM2 / FM2 / FM2 / FM1 socket
Heatpipes  4
Heat pipe Dimensions  6mm
Fans  2x120mm 650-1800 RPM
Air Flow  53.38 CFM
Air Pressure  1.65mmH20
Noise 31dB(A)
