CoolerMaster MasterLiquid ML240L RGB Review
Packaging and contents
The ML240L RGB comes in classic CoolerMaster packaging, with the glowing fans giving an idea that inside is something a little different.
The box exterior has all the usual Specifications and CPU compatibility, you know, for those of us who buy our coolers off the shelf in actual shops.
Inside it’s the good old save the earth egg box card, with each of the components being further by a not so Ecco friendly plastic bag. It’s fair to say this sort of packaging is pretty much industry standard, and it’s also fair to say we’ve never yet seen an AIO damaged on arrival.
Inside you get all the fittings you need for a whole range of Intel and AMD CPUs, including AM4 and Intel 2066. You also get cables and fittings to hook the fans and the cold head up to a small control box that comes supplied in order that the RGB element can be controlled.
Instructions are the usual CoolerMaster banner type, with images doing the talking although there are some multi language written instructions in areas. There are also links to online instructions if required.
