CoolerMaster MasterLiquid ML240L RGB Review
It’s fair to say that there are now a fair few AIOs on the market, with the 240mm Rad option being the sweet spot with regards to price and performance. With this in mind it’s perhaps not unexpected for a manufacturer to do something to lift there product above the others. Some manufacturers go for out right performance, some for low noise, and some for aesthetics, and other for software integration. CoolerMaster though have gone that little bit further and produced an AIO that is fully RGB enabled, with both the fans and the cold plate able to display a variety of colours. It even has a few tricks up its braided sleeves. For a little more detail on what you get for your money, best we have a look at the Technical Specification
| Model | ML240L RGB |
| Intel | Intel® LGA 2066 / 2011-v3 / 2011 / 1151 / 1150 / 1155 / 1156 / 1366 / 775 socket |
| AMD | AMD® AM4 / AM3 / AM3 / AM2 / AM2 / FM2 / FM2 / FM1 socket |
| Rad Material | Aluminium |
| Rad Dimensions | 277×119.6x27mm (LxWxD) |
| Fan Speed | 650-2000 |
| Air flow | 66.7CFM |
| Air Pressure | 2.34mmH2O |
| Noise | 6-30dB(A) |
