Corsair Graphite 380T Review
We’re starting to feel a bit sorry for other PC case manufacturers. You see Corsair are at it again adding more new members to the already excellent Graphite range. First up we’re going to have a good old gander at the 380T. It’s available in Black and White versions, or if you’re looking for something a little more individual, of course the eye catching Yellow we have for review. Those of you who have been following it up to release will most likely already know that it’s designed around the M-ITX platform and is intended to be a high airflow, highly portable enclosure. The 380T is able to accommodate both air and water cooling along with decent sized GPUs meaning that if you fall in love with it as a LAN rig you won’t have to scrimp on the contents. For a full run down let’s take a look at the Technical Specification.
| Dimensions | 393x292x356mm |
| Form Factor | M-ITX |
| Weight | 5.55kg |
| Colours | Yellow, Black, White |
| Storage | 2×3,5″, 2×22.5″ |
| Expansion | 2xPCI |
| Front I/O | 2xUSB3 Fan Controller, Audio in/out |
| Cooling |
Front: 1×140 included, 2×120 or 1×200 optional Rear: 1×120 included Side: 2×120 optional |
| Water cooling |
Rear: 1×120 radiator Side: 1×120 or 1×240 radiator |
| Max GPU length | 290mm |
| Max CPU cooler Height | 150mm |
| Max PSU length | 160mm (longer if HDD rack removed) |
Key Features
– Aesthetics that impress: sleek design, rounded corners, and easy to remove windowed side panels
– Built-in carrying handle makes it a portable powerhouse
– Included 140mm LED intake fan and 120mm exhaust fan
– Control freak? Customize cooling and noise level with the convenient three-speed fan controller
– Swap drives easily — without tools — in and out of the two 3.5¡¨ and two 2.5¡¨ drive bays
– Built-in internal lighting with to show off your system
– Easy connectivity with front panel USB 3.0, headphone, and microphone ports
– Maximum CPU Cooler Height -150mm
– Maximum GPU Length – 290mm
– Maximum PSU Length – 160mm
