EVGA DG-77 Review
The DG-77 we have for review today is part of the larger DG-7 range, which in simple terms cover options with ever increasing amounts of tempered glass and a choice of black or white. If you’re not a fan of tempered glass cases, then to be honest, it’s best you look away now. If however you love the tempered glass look, then this is a case you need to be looking at. To get a better idea of what the smoked glass interior is concealing, best we have a look at the technical specification.
Technical Specification
| Dimensions | 477x211x470mm (HxWxD) |
| Material | Steel and Tempered Glass |
| Motherboard support | ATX, M-ATX, M-ITX |
| 2.5″ | 4 (2 shared with 3.5″) |
| 3.5″ | 2 |
| Air Cooling |
Front: 3x120mm, 2x140mm (2x120mm included) Roof: 3x120mm, 2x140mm (1x120mm included) Rear: 1x120mm (Included) |
| Water Cooling |
Front: Up to 360, 280mm Roof: Rear: 1x120mm |
| Rear expansion | 7 |
| Front I/O | Power, Reset, HD Audio, 2xUSB3.0, K Boost |
| Weight | 8.79kg |
