Fractal Design Vector RS Review
Here at OC3D towers, having recently reviewed the Define S2 Vision, our collective jaws have only just recovered from hitting the floor. On opening up the latest offering from Fractal in the shape of the Vector RS it’s fair to say we felt the beginnings of yet another downward mandibular excursion. My God, this case is pretty; really pretty. Yes, pretty is important in the world of PC enclosures, but it also needs to perform. From a quick look at the Tech Spec below, it the Fractal Vector RS appears to have what it takes.
Technical Specification
| Dimensions | 552x223x498 (LxWxH) |
| Material | Steel Chassis, Plastic trim, Tempered glass panels |
| Weight | 12.64kg |
| Motherboard | M-ATX, ITX ATX, EATX (up to 285mm wide) |
| 5.25″ | 0 |
| 3.5″/2.5″ | 6 included, 11 positions total |
| Dedicated 2.5″ | 2 Included, 4 total |
| Front I/O | 1xUSB 3.1 gen 2 Type C, 2xUSB3.0, Audio in/Out |
| Expansion Slots | 7 2 vertical |
| Air Cooling |
Front: 3×120/140 (2×140 included) Roof: 3×120/140 Rear: 1×120/140 (1×140 included) Base: 2×120/140 |
| Water Cooling |
Front: 120/240/360. 140/280 Roof: 120/240/360. 140/280/420 (max 35mm component MB Height Rear: 120 Base 120/240, 140/280 |
| Max CPU Cooler Height | 185mm |
| Max GPU Length | 440mm |
| Max PSU Length | 300mm |
Key Features
- Bolt-free TG panels with push-to-lock latching
- Interchangeable top panels offer a choice of sleek tempered glass or filtered ventilation
- Counter angled intake vents designed to trap noise with minimal airflow resistance
- Customisable ARGB LED strip spans the top and front panels
- Set colours and effects via standard 5V RGB motherboard connection or included Adjust R1 controller
- Six HDD trays included 11 positions (additional Type-A trays sold separately)
- Two SSD (included with four positions available, (additional Type-A trays sold separately)
- Three Fractal Design Dynamic X2 GP-14 140 mm fans pre-installed
- Up to nine 120/140 mm fan positions
- Nexus fan hub manages up to nine fans via your motherboard
- Extensive water cooling support for radiators up to 420 mm in the top, 360 mm in the front, and 280 mm in the base
- Ventilated PSU shroud conceals cables and provides additional SSD mounting options
- Modular design converts from a storage focused standard layout to a cooling centric open layout
- Support for Flex VRC-25 vertical GPU riser (sold separately)
- USB 3.1 GEN 2 Type-C
