Noctua NH-U14S Review
It’s fair to say that Noctua have established themselves something of a reputation in the air cooler market. This is in no small part due to the excellent performance of the class leading NH-D14. However, it wouldn’t be unreasonable to note that that although the D14 is a true performer it is a little on the large size and as such it’s possible that it may cause you some compatibility issues, especially if you’re toting tall RAM. Enter then the NH-U14S, a slim line single tower at only 78mm deep with the supplied NF-15 PWM fan Noctua boast a high degree of motherboard compatibility. Although we’re not expecting the NF- U14S to match or even get close to the D14 it still has a lot to live up to if it’s going to wear the Noctua badge so lets have a look at the full technical Specification to see if the right ingredients are there.
Technical Specification
Intel Compatibility |
Socket 2011 |
AMD Compatibility |
Socket FM2 |
Dimensions without fan |
165x150x52mm (HxWxD) |
Dimensions with fan |
165x150x78mm (HxWxD) |
Fan |
NF-A15 PWM 1500RPM |
Air Flow |
82.5 CFM 67.9 CFM using LNA |
Sound Level |
24.6 dBA |
Fan Speed |
300 to 1500 RPM PWM |
Fan Connection |
4 Pin PWM |
Fan Dimensions |
140 x 150 x 25mm |
Approx Cable Length |
300mm |
Fan LED Colour |
n/a |
Materials |
Nickel Plated Copper heat pipes and base |
Heat Pipes |
6 in spread “U” form |
Special Features |
Slim Cooler |
Package Contents |
1 x Noctua CPU Cooler |
