NZXT Kraken Core 360 All-in-One CPU Liquid Cooler Review
Thermal Testing – Cinebench R24
OC3D CPU Cooler Stress Test
We want to push CPU coolers to their limit, and that requires a workload that will place maximum load on our i5-14600K CPU. Why didn’t we choose an i7 or an i9? The simple answer is that we want to test various CPU Cooler options. If we put the hottest CPU we could in our system, only the best of the best CPU coolers would even pass our testing procedures. Since not everyone uses such a power-hungry CPU, we decided to tone the wattage and thermal loads down by using an i5-14600K. Even so, this CPU consumes a lot of power and generates a lot of heat under all-core workloads.
For testing, we have used Cinebench R24. This is an all-core workload that places heavy strain on all available CPU cores. This load pushes CPU thermals higher than any other and does so consistently. We use Cinebench R24 for 30 minutes to see how hot our CPU gets over that time. If CPU temperatures rise to 100 degrees Celsius or over, that CPU cooler has failed our testing. This is part of the reason why there are more coolers on our higher fan RPM cooler charts. Some coolers will pass our thermal testing at higher fan RPMs but fail at lower fan RPMs.
1,000 RPM Fan Test
With an asking price of under £80, the NZXT Kraken Core 360 delivers exceptionally good cooling performance. Yes, it isn’t the best on our charts, but it beats a lot of coolers that are more than 2x as expensive. NZXT has clearly bundled their cooler with good fans, as its low-RPM performance is stellar.
1,500 RPM Fan Test
At 1500 RPM fan speeds, the NZXT Kraken Core 360 continued to deliver strong performance numbers. Once again, it beats many more expensive coolers from competitors. It even beats some of NZXT’s older Kraken Elite V2 series coolers.
Max RPM Fan Test
At this cooler’s maximum fan speed of 2050 RPM, the NZXT Kraken Core 360 delivers exceptional value for money. At its current price, this cooler is an excellent value. It may lack RGB lighting, but it isn’t lacking when it comes to cooling performance.
