NZXT Kraken Core 360 All-in-One CPU Liquid Cooler Review
Is the NZXT Kraken Core 360 the budget cooling king?
If there is one thing that NZXT’s Kraken Core 360 proves, it’s that “budget” doesn’t mean “bad”. This CPU cooler delivered strong cooling performance across our testing, both at high and low fan speeds. Many budget CPU coolers cheap out on their fans, resulting in sub-par performance and high noise levels for end users. NZXT has not fallen into this trap. This cooler pairs Asetek’s new Gen 9V pump with its own pressure-optimised single-frame F360P fan set. The result is cooling performance that punches far above this cooler’s pricing tier.
For £71.20, this cooler delivers exceptional cooling performance. It handily outperforms every air-based CPU cooler we have tested, and many more expensive liquid-cooling solutions. The downsides are that this cooler lacks RGB lighting and doesn’t have an LCD screen or similar add-ons. This CPU cooler focuses on keeping your CPU cool, not on flashy gimmicks. If you hate these trends, this is the CPU cooler for you. If you want these additions, expect to spend much more for equivalent cooling performance.
The Kraken Core 360 is a no-nonsense CPU cooler. It has everything it needs and nothing more. It even uses a single-frame fan setup to reduce the number of cables and fan screws needed. This liquid cooler has two cables. One for the fan and one for the pump. Thermal paste is pre-applied, so users can mount this cooler into their systems with ease. This cooler is simple and effective.
With an asking price of £71.20 in the UK, the NZXT Kraken Core 360 delivers exceptional value. It competes favourably with coolers that cost more than twice as much and is elegant in its simplicity. Yes, it lacks RGB flash and skips the LCD trend, but if you want strong cooling performance at a better price, this is the CPU cooler for you. The NZXT Kraken Core 360 deserves nothing less than our Value for Money Award.
Join the discussion on NZXT’s Kraken Core 360 AIO CPU Liquid cooler on the OC3D Forums.
